Помогите установить пожалуйста...
mono winform 2.0 установлен...
как быть????
При запуске в консоли выдает:
KDE colorscheme read failure, using built-in colorscheme
libpng warning: iCCP: known incorrect sRGB profile
libpng warning: iCCP: cHRM chunk does not match sRGB
- [AppDir] HTML Export (1.13.5737.24525)
- [AppDir] Export to image (1.9.5737.24526)
- [AppDir] Picture Region (1.10.5737.24525)
- [AppDir] Plot Region (1.9.5737.24527)
- [AppDir] SMath Studio Files Plugin (1.9.5737.24527)
- [AppDir] Special Functions (1.11.5737.24524)
- [AppDir] Text Region (1.10.5737.24526)
- [AppDir] SMath Viewer Files Plugin (1.1.5737.24528)
- [AppDir] XMCD Files Plugin (1.12.5737.24526)
Stacktrace:
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdipLoadImageFromDelegate_linux (System.Drawing.GDIPlus/StreamGetHeaderDelegate,System.Drawing.GDIPlus/StreamGetBytesDelegate,System.Drawing.GDIPlus/StreamPutBytesDelegate,System.Drawing.GDIPlus/StreamSeekDelegate,System.Drawing.GDIPlus/StreamCloseDelegate,System.Drawing.GDIPlus/StreamSizeDelegate,intptr&
<0xffffffff>
at System.Drawing.Image.InitFromStream (System.IO.Stream) <0x001c3>
at System.Drawing.Bitmap..ctor (System.IO.Stream,bool) <0x00023>
at System.Drawing.Bitmap..ctor (System.IO.Stream) <0x00017>
at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap..ctor (System.IO.Stream) <0xffffffff>
at SMath.Manager.GlobalParams.GetImageFromResources (System.Reflection.Assembly,string) <0x00053>
at .. (.,string[2]) <0x00143>
at .. () <0x02e7b>
at .. (object,System.EventArgs) <0x00c13>
at System.Windows.Forms.Form.OnLoad (System.EventArgs) <0x00062>
at System.Windows.Forms.Form.OnLoadInternal (System.EventArgs) <0x00084>
at System.Windows.Forms.Form.OnCreateControl () <0x00057>
at System.Windows.Forms.Control.CreateControl () <0x0012f>
at System.Windows.Forms.Control.WmShowWindow (System.Windows.Forms.Message&
<0x00117>
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message&
<0x002b3>
at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message&
<0x00013>
at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message&
<0x00057>
at System.Windows.Forms.Form.WndProc (System.Windows.Forms.Message&
<0x0023f>
at System.Windows.Forms.Control/ControlWindowTarget.OnMessage (System.Windows.Forms.Message&
<0x0001a>
at System.Windows.Forms.Control/ControlNativeWindow.WndProc (System.Windows.Forms.Message&
<0x0002b>
at System.Windows.Forms.NativeWindow.WndProc (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x001ec>
at System.Windows.Forms.XplatUIX11.SendMessage (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x002b3>
at System.Windows.Forms.XplatUIX11.MapWindow (System.Windows.Forms.Hwnd,System.Windows.Forms.WindowType) <0x0019e>
at System.Windows.Forms.XplatUIX11.CreateWindow (System.Windows.Forms.CreateParams) <0x00be3>
at System.Windows.Forms.XplatUI.CreateWindow (System.Windows.Forms.CreateParams) <0x0001a>
at System.Windows.Forms.NativeWindow.CreateHandle (System.Windows.Forms.CreateParams) <0x00033>
at System.Windows.Forms.Control.CreateHandle () <0x0007a>
at System.Windows.Forms.Form.CreateHandle () <0x00017>
at System.Windows.Forms.Control.CreateControl () <0x0008b>
at System.Windows.Forms.Control.SetVisibleCore (bool) <0x0007b>
at System.Windows.Forms.Form.SetVisibleCore (bool) <0x00227>
at System.Windows.Forms.Control.set_Visible (bool) <0x00029>
at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control.set_Visible (bool) <0xffffffff>
at System.Windows.Forms.Application.RunLoop (bool,System.Windows.Forms.ApplicationContext) <0x0020b>
at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext) <0x0004f>
at System.Windows.Forms.Application.Run (System.Windows.Forms.Form) <0x00037>
at .. (string[]) <0x001eb>
at (wrapper runtime-invoke) <Module>.runtime_invoke_void_object (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
/usr/bin/mono() [0x80e5f22]
/usr/bin/mono() [0x81220ba]
/usr/bin/mono() [0x8066649]
[0xb76e7bc8]
/usr/lib/libgif.so.7(DGifGetExtension+0x5c) [0xb58659ec]
/usr/lib/libgdiplus.so.0(+0x44f7a) [0xb5b8bf7a]
/usr/lib/libgdiplus.so.0(+0x465f2) [0xb5b8d5f2]
/usr/lib/libgdiplus.so.0(GdipLoadImageFromDelegate_linux+0x1b4) [0xb5b73d74]
[0xb45be2f8]
[0xb45bdb44]
[0xb45448d4]
[0xb4544898]
[0xb4544858]
[0xb450d47c]
[0xb3ec1e0c]
[0xb3ebbe1c]
[0xb455a7fc]
[0xb4557823]
[0xb45572ed]
[0xb4557220]
[0xb520f500]
[0xb51f6b50]
[0xb51f5e8c]
[0xb4553acc]
[0xb4553a90]
[0xb45538e8]
[0xb51f5bd3]
[0xb51f5bac]
[0xb51f4efd]
[0xb51f350c]
[0xb51f682f]
[0xb52105ec]
[0xb520fa03]
[0xb520f984]
[0xb520f703]
[0xb4551a48]
[0xb520f45c]
[0xb51fe0ec]
[0xb4551620]
[0xb51fe03a]
[0xb51fdfdc]
[0xb45505cc]
[0xb4550370]
[0xb4550010]
[0xb65f0494]
[0xb65f05df]
/usr/bin/mono() [0x8066071]
Debug info from gdb:
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Предупреждение: Сбой программы «/usr/bin/mono».
