Уведомление
Вход
Опции
Offline уни
#1 Оставлено : 9 ноября 2010 г. 20:56:56(UTC)
уни
Статус: Advanced Member
Группы: Registered
Мужчина
Российская Федерация
Сказал «Спасибо»: 50 раз
Список функций:
rkfixed(), Rkadapt(),
rkm9st(), mk52lfn(), mk52lfa(), rkm9mkn(), rkm9mka().
Решатели нежёстких систем ОДУ:
rkfixed(init, x1, x2, intvls, D) Uses the fourth-order Runge-Kutta fixed-step method.
Rkadapt(init, x1, x2, intvls, D) Uses the fourth-order Runge-Kutta with adaptive step-size.
Intel ODE Solvers Library:
rkm9st(init, x1, x2, intvls, D) A specialized routine for solving non-stiff and middle-stiff ODE systems using the explicit method, which is based on the 4th order Merson’s method and the 1st order multistage method of up to and including 9 stages with stability control.
mk52lfn(init, x1, x2, intvls, D) A specialized routine for solving stiff ODE systems using the implicit method based on L-stable (5,2)-method with the numerical Jacobi matrix, which is computed by the routine.
mk52lfa(init, x1, x2, intvls, D) A specialized routine for solving stiff ODE systems using the implicit method based on L-stable (5,2)-method with numerical or analytical computation of the Jacobi matrix. The user must provide a routine for this computation.
rkm9mkn(init, x1, x2, intvls, D) A specialized routine for solving ODE systems with a variable or a priori unknown stiffness; automatically chooses the explicit or implicit scheme in every step and computes the numerical Jacobi matrix when necessary.
rkm9mka(init, x1, x2, intvls, D) A specialized routine for solving ODE systems with a variable or a priori unknown stiffness; automatically chooses the explicit or implicit scheme in every step. The user must provide a routine for numerical or analytical computation of the Jacobi matrix.
Параметры:
- init is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE - not implemented yet).
- x1 and x2 are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
- intvls is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
- D is a vector function of the form D(x,y) specifying the right-hand side of the system
Ссылки:
1. Intel ODE Solvers Library.
Отредактировано пользователем 23 августа 2013 г. 17:13:03(UTC)  | Причина: Не указана
Вложение(я):
ODE_manual.pdf (240kb) загружен 262 раз(а).
Россия навсегда!
thanks 1 пользователь поблагодарил уни за этот пост.
mikka оставлено 10.11.2010(UTC)
Offline OchkovVF
#2 Оставлено : 9 ноября 2010 г. 23:04:37(UTC)
OchkovVF
Мужчина
Сказал «Спасибо»: 210 раз
Поблагодарили: 3 раз в 3 постах
Текст функции rkfixed
communities.ptc.com/videos/1471
Текст функции rkadapt
http://twtmas.mpei.ac.ru...s/worksheets/rkadapt.mcd
если это кому интересно.
Offline уни
#3 Оставлено : 10 ноября 2010 г. 8:31:53(UTC)
уни
Группы: Registered
Мужчина
Спасибо, Валерий Фёдорович, приму во внимание.
Вот плагин с функцией rkfixed(): ODESolvers.dll
Исходник: ODESolvers_Class1.pdf
Вот примерный документ: rkfixed.sm
Примечания:
1. Функция системы должна быть вектором.
2. Имена переменных (t,x) могут быть любыми.
П.С. Там в цикле while() есть небольшая ошибка.
Поскольку это всё равно транслятор, то работает относительно медленно.
Самое смешное, что аналогичная функция, написанная в документе в виде программного блока работает всего на немного медленнее этой реализации ("подушка" посчиталась на 30 секунда быстрее, всего время расчёта для rkfixed() на моём компе около 3 мин 10 сек).
Код:
if ( система[n].Equals( перем_x ) && система[ n + 2 ].Equals( Элемент ) )
Здесь (n+2) теоретически может превысить размер вектора элементов системы. Надо будет поправить на досуге.
Отредактировано пользователем 10 ноября 2010 г. 9:12:46(UTC)  | Причина: Не указана
Россия навсегда!
thanks 2 пользователей поблагодарили уни за этот пост.
mikka оставлено 10.11.2010(UTC), GhostTraktor оставлено 11.12.2011(UTC)
Offline smath
#4 Оставлено : 10 ноября 2010 г. 10:58:34(UTC)
smath
Статус: Administration
Мужчина
Сказал «Спасибо»: 640 раз
Спасибо за плагин.
уни написал:
Личным сообщением на форуме послал Вам логин и пароль для доступа к репозиторию на запись. Думаю удобнее код будет иметь там.
thanks 1 пользователь поблагодарил smath за этот пост.
уни оставлено 10.11.2010(UTC)
Offline уни
#5 Оставлено : 10 ноября 2010 г. 11:44:27(UTC)
уни
Группы: Registered
Мужчина
Да, я заметил логин и пароль, спасибо. Пока не буду мусорить в репозитории. Последний год я привык писать на русском (пишу в одиночку), а в репозиторий нужно переписывать всё на английском. Пока лень.
Если добавить ещё несколько решателей, то, пожалуй, можно будет их залить. Меня не устраивает скорость работы. Всё равно медленно.
Отредактировано пользователем 10 ноября 2010 г. 11:46:14(UTC)  | Причина: Не указана
Россия навсегда!
Offline уни
#6 Оставлено : 11 ноября 2010 г. 22:27:18(UTC)
уни
Группы: Registered
Мужчина
В качестве тестовой версии предлагаю Rkadapt(). Исходник является компиляцией кода Валерия Фёдоровича и приведённого в книжке "Numerical Recipes in C", откуда он собственно и был взят. Я подгонял его под фиксированные шаги как в Маткаде, чтобы вызов их был идентичен. Получилось не совсем ещё хорошо, но пока работает.
Примечание. Возможны случаи при большом количестве шагов (больше 100, к примеру), когда в конце вектора решения будут один или несколько нулей.
Плагин: ODESolvers.dll
Документ: Rkadapt.sm
Отредактировано пользователем 11 ноября 2010 г. 22:33:48(UTC)  | Причина: Не указана
Россия навсегда!
Offline уни
#7 Оставлено : 12 ноября 2010 г. 11:14:06(UTC)
уни
Группы: Registered
Мужчина
Лучше тестируйте вот эту версию: ODESolvers.dll От 12.11.2010 г.
Здесь я уже понял ту фишку, которую использовали маткадовцы, когда адаптивный шаг "пристраивали" к фиксированной сетке. Работает гораздо быстрее и правильнее. Убрал многие ошибки. Теперь получается тоже, что и с rkfixed(), но гораздо точнее в тех же точках.
Отредактировано пользователем 12 ноября 2010 г. 11:27:59(UTC)  | Причина: Не указана
Россия навсегда!
Offline уни
#8 Оставлено : 12 ноября 2010 г. 14:51:13(UTC)
уни
Группы: Registered
Мужчина
Андрей, тут я заметил одну проблему, когда правил плагин:
Россия навсегда!
Offline smath
#9 Оставлено : 12 ноября 2010 г. 16:35:29(UTC)
smath
Мужчина
Функция if разбирается только в Preprocessing и не определяется в численной и/или символьной библиотеках.
Offline уни
#10 Оставлено : 12 ноября 2010 г. 18:31:30(UTC)
уни
Группы: Registered
Мужчина
Да, это даже наверное логично. Исправил плагин: ODESolvers.dll
Алгоритм Rkadapt(): Rkadapt prog.sm
К сожалению, я не смог заставить его работать, т.к. не понял где ошибка в записи выражения.
Здесь ещё нет защиты от зацикливания при выборе шага.
Ещё пример работы:
Отредактировано пользователем 12 ноября 2010 г. 21:12:35(UTC)  | Причина: Не указана
Россия навсегда!
nickgoblin оставлено 31.01.2011(UTC)
Offline уни
#11 Оставлено : 12 ноября 2010 г. 21:25:02(UTC)
уни
Группы: Registered
Мужчина
Эксперименты с ушами:
Россия навсегда!
Offline уни
#12 Оставлено : 14 августа 2013 г. 12:01:07(UTC)
уни
Группы: Registered
Мужчина
Обновлён. Добавлены функции из Intel ODE Solvers Library: rkm9st(), mk52lfn(), mk52lfa(), rkm9mkn(), rkm9mka().
Также как и в DotNumerics можно использовать переменные AbsTol и RelTol в документе для задания точности вычислений.
Вложение(я):
ODE_manual.pdf (240kb) загружен 91 раз(а).
Россия навсегда!
Ber7 оставлено 14.08.2013(UTC)
Guest (2)
Быстрый переход
