Register
Login
Search
Issues Tracker
Home
Project
ยป
Roadmap
Change Log
Search
Issues
Queries
-- Select Project --
SMath Studio
SMath Studio in the Cloud
SMath Viewer
Home
Issues
View Issues:
-- Select a View --
All Issues
Open Issues
Add / remove columns
Export
RSS
Set properties for selected issues:
Category
Owner
Milestone
Affected Milestone
Type
Resolution
Priority
Status
-- Select Status --
Assigned
Due Date
Reset Due Date
Select columns:
Votes
Category
Creator
Owner
Assigned
Type
Milestone
Affected Milestone
Status
Priority
Resolution
Due Date
Estimation
Progress
Time Logged
Created
Last Update
Last Update User
Id
Title
Votes
Category
Creator
Owner
Assigned
Type
Milestone
Affected Milestone
Status
Priority
Resolution
Due Date
Estimation (hrs)
Progress
Time Logged (hrs)
Created
Last Update
Last Update User
SS-4684
[Maxima] Custom translations in maxima.xml don't work
1
Plug-ins
Unassigned
none
0.00
0
6/15/2022
6/15/2022
SS-4683
[Maxima] Adjust string handling to modified encoding in newer SMath versions
1
Plug-ins
Unassigned
Unassigned
none
0.00
0
6/14/2022
6/14/2022
SS-4682
UI glitch in SMath Solver - Extension manager 1.0
1
User Interface
smath
Unassigned
none
0.00
0
4/30/2022
4/30/2022
SS-4681
Sheet won't open
1
Calculations
JR33
JR33
smath
Unassigned
4/12/2022
0.00
0
4/5/2022
4/5/2022
JR33
SS-4680
[Maxima Plugin] translation problem of variable names with prime
1
Plug-ins
Unassigned
none
0.00
0
1/31/2022
1/31/2022
SS-4679
Maxima Draw region: overgreedy error detection
1
Plug-ins
Unassigned
none
0.00
0
1/27/2022
1/27/2022
SS-4677
Cant open file error "incorrect file ending detected. One or more regions may be missed at the end of the WOrksheet.
1
Unassigned
Janusz Zaba
Janusz Zaba
smath
Unassigned
Unassigned
none
0.00
0
11/28/2021
11/28/2021
Janusz Zaba
SS-4676
Complex Solutions of (-1)^x
1
Calculations
Davide
Davide
smath
Unassigned
none
0.00
0
11/11/2021
11/11/2021
Davide
SS-4675
Smath snippet gives error/crash when inserted with a title
1
Plug-ins
Arto Niskanen
Arto Niskanen
smath
Unassigned
Unassigned
Unassigned
none
0.00
0
11/11/2021
11/11/2021
Arto Niskanen
SS-4674
A previously saved file does not open. iPhone 6 plus
1
User Interface
chaus
chaus
smath
Unassigned
none
0.00
0
9/21/2021
9/21/2021
chaus
Show rows:
5
10
15
25
50
75
100
1 - 10 of 298
